xctasy":14pqq5kw said:
...then you test and optimize it. There is no other way." Transfering that maxim, one can only consult on an existing package, then then suggest if advancing or retarting a stock cam angle setting will work. That's the true science-meets-art of cam selection. All we want is to get the cam making good pressure to yield torque where its wanted. ....
No disagreement with that whatsoever. However, the point at which you call a combination optimized may be where are thoughts may differ. First and foremost, an engine is an engineering and math quantifiable system. Depending on the tool/s used, the level of optimization might be simply an optimum fuel sytem/ignition system tuning, camshaft alignment or lash experimentation of an existing combination which may not be anywhere near optimized, as far as flows, velocities, displaced volumes and cylinder pressures are concerned, but the tuning, at hand, simply cannot be improved upon any more. Or on the other side of the coin, it may be a detailed look at inlet and outlet cross-sections, and their parameters in terms of flow quantity, flow quality, velocity, and valve events and ramp rates, in relation to displaced cylinder volumes. This is the perspective I look at the engine combinations. From this point optimization is baselined, AND THEN the real world testing becomes the slight modifications to completely vamp the combination. Even at that point it may be another camshaft (or even 3 more), after testing lash response or rocker ratio, or a host of other seemingly small effects that can make a huge difference, or other peripheral components. It may be that the lash exeperiments were indicating a decreased flow potential/capability on the inlet or outlet may be beneficial. on and on and on.
My comments on cam positioning are based in math modeling of the inlet and outlet parameters versus the displaced volumes. IT is very hard to argue that a restricted motor can benefit from lazy and delayed intake valve events and early exhaust valve events. The math bares this out, just as real world bears this out. Based on that premise, as well as cam calcs and customers, aggressive early intake and very delayed exhaust (the quantification is dependant on the amount of exhaust restriction) are what is required, be it racing or towing. The ford 252/256 cam is a awesome example of this, with its extremely delayed exhaust events centerline at 107 degrees, but the likewise delayed lazy intake events just simply do not provide a good cylinder fill. The cam simply needs a narrower lobe separation angle (period). Likewise the 256/256 as well. But in this case, they rocked it way to the other side. The intake events are pretty nice, but the the exhaust events centerline is way way too early at 119 degrees. It too simply needs a narrower LSA. The small six cams would do better if utilizing the valve events of the 240/300 cams ~265/265/110, installed at 110/110.
You made a statement regarding using valve events to get the torque placement where you want it. Actually the torque peak is dependent on port velocity and cylinder fill. In optimum conditions, the valve events do not necessarily control where this occur, they either allow it to occur or they penalize it by attempting to rewrite the torque peak rpm. The valve events can add cylinder fill earlier, which can increase some torque and fill the lower end of the power curve (giving more usable area under the curve- better torque, better shift recovery, etc). Or they can do the opposite. But each time it can be a penalty in reference to where the motor geometry is wanting to go. There is absolutely nothing wrong with wanting a motor to run counter to its geometry (that is the whole point many times), but that is a different kind optimization. That is an acceptance of an ill matched combination, and optimization of whats there, within the constraints of the inlet/outlet/cid/rpm/etc. Those are the scenarios at which the corrective paths may run counterintuitive to the norm. The end result is often that the previously thought intuitive paths must have been incorrect becuase they did not apply in the specific case. This is often the end thought process after testing severely out of whack combinations. The previously thought intuitive "path" is blamed instead of the engine combination itself and its response to the change. In reality, those counterintuitive paths were actually the real world application of the intuitive paths, but the engine combination itself was masking the end outcome, making it look like the intuitive path was incorrect.
We cannot take an extremely non-optimized combination and apply typical techniques of optimization. Their face-value global application does not work, because there are other pieces of the puzzle that may be dominating the situation. For example retarding a camshaft can actually bring the motor closer to optimization and the actual rpm peaks and top rpm decrease. This is counterintuitive because retarding a camshaft is globally thought to raise peaks. What if the cam was so far out of whack thats its response was completely masked by other flow problems in the motor.
In the statements referenced concerning the only reality is in the real world testing does fit this thread to a tee. However, there are parameters that are 100% addressible and easily calculated pointing the direction (or trend ) things need to go. This puts the optimization at a higher level, and at that point things can make a lot more sense. The best way to address the changes, outside of the math, is to step back, observe, and say there are no real guidelines, no absolutes, all responses come from test results, with the specific combination at hand. As is the case that Jack Braham (I assume Brabham) references; it is absolutely 100% correct. However, the math and engineering can reveal a different story. They can demonstrate the trend to follow, and testing therefore becomes a tuning exercise of confirmation (or failures) with minor turns and joggles. An accurate math model is required.
