canvaspaul
You can hook it up or just loosen the choke cover screws and turn cover so that the choke blade is opened up all the way.
This is the solution, no choke, probably I was to careful in turning the choke (to disable it) Put the vacuum hoses back in place like in my car with one vacuum line closed up.
First turn over and the engine runs with the normal gas consumption, runs quit well. tomorrow I will get the engine on working temperature en make a small film and measure the compression and post it.
