bones 92":1d0nf82e said:I hate to sound stupid in this question, but I just went outside and looked for the N or T again and maybe I don't understand where this should be. I looked on the right front top of the head and don't see a flat bossed area. Do I have to remove something to see it? I saw the picture but I guess its not clear enough for me to understand. (I know I will feel silly once I find it) I will scrape some more junk tomorrow after work..
No you don't need to remove anything but this boss is also not on top of the head, It's location is on the top of the short block assembly. In the above posted picture you are looking at the top of the cylinder blocks deck surface. Follow the head down to its bottom surface were you will see the parting line at the head gasket between the head surface and the top of the blocks deck surface. This is where the boss is located (on the drivers side front of engine).
You said the plugs are bone dry after it shuts off! So next time the engine stalls or right now if it still won't start do a recheck of the fuel pump test to see if it's still pumping any fuel volume. Good luck
