Not to start a war....but, since I also own a MOPAR, I study those hopups, too
.... and one of those hopups fit our sixes!
One that's VERY applicable to these sixes is the 30-degree intake valve angles that have become standard on drag racing engines of all kinds, popularized by the MOPAR crowd. This angle is possible on our sixes (at least, as I measured it on the late-model head) because the valve size is right and the intake tract just happens to be at the right angles!
What this is about, for the uninitiated, is this: changing the face of the valve and valve seat to 30 degrees at the sealing face (instead of the standard 44/45 degrees) causes a LARGE flow increase at the beginning of the intake stroke. This results in the same effect as adding (in a MOPAR 360 engine) 12 degrees of intake valve duration, but without losing the compression that a long intake duration would cause.
The tests I saw showed 15% increase in flow at the point where the valve is open .030" to .080" on it's way open (and closed). The flow is only increased about 5% when the valve is fully open (.410" lift on this engine), but the extra from the beginning and end are still there.
The dyno results after reworking the valve seats are undeniable and repeatable on the 318 and 400 engines as well. Now, I want this on MY 200.
To get it, the intake valve must be back-cut, then the seats recut to 45/30/15 degrees instead of the stock 60/45/30. This will require a little blending work in the chamber, which will increase the volume, so it's gotta be milled again.. :roll: :roll:
I gotta find me another head. :idea:
