spark plugs?
mluck
i'm running with the offy, header,cam,etc....i think i have it slighty advanced...should i run with a colder plug...hotter?..what brand should i use...
Easiest and cheap way to find out (you're going to get a lot of opinions on this) is to buy some cheap copper motorcraft spark plugs ($.99 ea) and try those. If the look like they are running too hot, go with platinum.
Slade
Howdy Mluck:
What do yur plugs look like now? Are they whitish and/or chalky? Is the electrode purning away? If so try a step colder in the same type/brand as you are now using. If you change brands start with the reccomended head range for your engine then go from there by reading the plugs,
Typically I will use a one step colder plug in the summer.
