When checking total advance at high engine rpms 4000-5000 i am starting to get some spark scatter which anyone with chevy experience is the norm because of the distributor at the rear of the camshaft getting harmonics & from driving the oil pump. On the chevys i run a moroso anti-cavitation oil pump which cuts the scatter in half.
On the small six im thinking it may be due to the duraspark distributor having no lower bushing & i am getting fluctuations from shaft flex.
I replaced the pickup coil in the distributor but noticed no change. both pickups ohmed out at close to 600 which is in the middle of the correct ohm range.
My option is get a distributor from Performance distributors which has the full length bushing for better shaft support.
The camshaft drive gear is starting to show some wear, but the distributor gear looks perfect.
When some of you members get a chance put a timing light on your engine at high engine speeds & let me know what you find & what distributor are you running.
Spark scatter is the timing mark jumping around & is not rock steady like it should be at high engine rpms.
I may give Mike a call & purchase one of his rebushed distributors with a full length bushing.
I know he sells motorcraft remans, but they probably lack a lower bushing.
Advise next time you put a timing light on your engine. Thanks
