Help!!! My car has suddenly developed a problem with stalling out. It happens in all types of weather and both when the car is hot or cold. The problem started with a little hesitation at steady highway speeds (65 or 70 mph), then the car began to surge followed by either backfiring or stalling out. It does this intermittently. Sometimes I can go for a week without it happening, other times I can not drive more than 5 minutes without it happening. Sometimes when it happens, I can feather the gas pedal, and the engine with come back to life, other times, it will just die.
The specs on the car are as follows:
1965 Ford Mustang with a 1981 200 engine, C4 auto, Duraspark II ignition, with an alternator, 3.2 rear end. I am unsure what carb I have, but it is the original from the donor 81 Mustang six cylinder. The ignition key portion of the ignition switch is new, but not the contact portion (although jiggling the key does not help or hurt the problem).
Thus far, I have tried the following, none of which have worked:
1. Replaced the electronic ignition control box as my car with a new one;
2. Put IsoHeet in the tank, just in case I had water in the gas for some reason;
3. Changed brands of gas and octane levels ( I generally run BP Amoco Silver 89 Octane gas);
4. Changed the fuel filter, it did not appear to be dirty;
5. Checked all ignition wires, plug wires, rotor, distributor cap, coil. All appear to be good. Spark plugs are AC Delcos that have about 8,xxx miles on them;
6. Oil was just changed (but problem began after oil change);
The car will fire right up and idle fine after it stalls out. I can rev the engine and take right off, with no other occurences generally for at least 5 more minutes.
The fuel pump, all fuel lines, gas tank, sending unit were all replaced together about 18 months ago. The timing chain was changed last year when I swapped in the engine. The entire engine
The only four original ignition parts are the coil, ignition switch, plug wires and distributor. All are from the donor 81 Mustang. The carb appears pretty nasty on the outside, but has never given me any other trouble. The car idles fine when it is cold or warm and never overheats.
One persistent problem I have had with this car is poor gas mileage since swapping in the C4, but I figured it was the nature of the beast.
Does anyone have any suggestions regarding what I should check next or what I may have missed?
I have ruled out timing, but am not sure if the coil or fuel pump are going bad. Also curious if I need a carb rebuild as I am not sure of the last work done to it.
Please let me know what you think.
Kurt.
Kurt.
