TucsonHooligan":1wy7u7ko said:
I've gone thru and checked all the stuff thats supposed to match this tranny...The flexplate is correct for the year tranny
Okay, I don't know alot about the C4's, but as I understand it there are different 'bellhousings' available.
I would think you need the
date code off the 'bellhousing' as the valve bodies (aka rest of the tranny) is interchanable between different year 'bellhousings' IIRC...AFAIK
bellhousing should dictate starter and flex plate/ring gear.
Did the 'bellhousing' and the rest of the tranny come as a package or acquired piecemeal, or have they been used togehter before?
I believe there is more than one flexplate available for the C4 behind the ford six...I believe you need the one that went with the 'date code' of the bell housing you have. The flex plate size and tooth count is going to locate the ring gear teeth to a particular location in the BH, that should match up with a particular starter...I'd still bet your flex plate may be the issue...wasn't there even a C4 where the ring gear was on the torque converter, or was that the cruis-o-matic
For the starter, if push came to shove you could likely swap the nose cone over from the three bolt you have if the bendix is shot, or just replace the bendix gear.
FSP member 'Crosley' knows a good bit about automatics IIRC, you might even consider pm'ing him.
I could be way off, completely wrong....wouldn't be the first time, but still would think this is the key :idea:
I have the earlier style bellhousing attached to it with the high mount
You don't have a cruise-o-matic BH do you?....do those work together?Good luck!
EDIT: apologize for epic length here, and if I'm steering you completely wrong <flame on>...I'm sure there are other members with significant experience with the C4...surprised if your issue has not come up before. I'm just suggesting above cause it seems to make sense to me at least.
