strut setup is ready [ pic ]
struttower setup is ready and complete bolt in , only some finishing touch to do , the other 1 is for jimbo!
LinkPhoto
LinkPhoto
LinkPhoto
this 1 is for jimbo , just waiting for some mivnor parts ,
LinkPhoto
here some pic from water cutting !
LinkPhoto
LinkPhoto
LinkPhoto
maybe you can see , got another setup , like a export brace system and a new idee for the tower mounth/strutsetup plate in 1 piece desing ! THX asa67_stang !!!! 8)
it was my pleasure man
that looks very sexy, can't wait for the website to be up and running so i can get one for myself
just let me now wat you want . i make you a special deal for the new idee you give me !
i got 1 struttower left ! not all complete only missing the rod ends !
and a new desing for tower brace
LinkPhoto
LinkPhoto
Not missing the rod ends...
I bought two sets for you Harrie...
They are on their way to my house...
then I will ship them to you... I figured you could use an extra set... plus more for you for doing this for me...
If these work out and are the right ones... (I hope they are)
then you we could order more in the future if you need them.. and I can ship them to you....
you want the set with the new design strutower , shock mount setup ?
ore with the orginal ,that is showing in the pic ?
the new desing come,s in 2 hight,s for when lowering the car !
1 x 70 M/M
1 x 85 M/M
I would like the original... like in the pic...
I have a issue with the rod ends... funny guy just called me.
The M10 1.5 are only available in RH thread for the Male.
and they are 29mm length... with the 1.5 pitch that is 43/44 threads?
this seems wrong. So I have him holding. He can get LH/RH in Female not male... :roll:
Harrie I found another place that can make them if they do not have them in stock...
but with all the different numbers I am confused as to what we need...
Can you give me in mm the size and length you want...
say M10-1.5 LH/RH... in what length to get 60 threads? the way they explain it to me... 1.5 is like coarse here in US... and 1.25 is fine... only available in M8...
my first proto was also all RH tread , i did adjust them out the car and bolt them in with the right dimension , normaly with RH/LH tread you can adjust in the car , is this realy nessesery ? you only have to adjust 1 x !! and bolt in when your using only RH tread ! and the 29 M/M wil do i think. gonne messering it tomorrow, and wil let you now if the 29 M/M wil do !
This other place in Maryland has the M10 in both 1.5 and 1.25 and both LH and RH thread.... so we are set... I will call them in the morning they are closed now...
