I'm replacing the valve cover gasket on my 200ci. At first it was a small seep, but now I'm losing alot of oil in some places. A couple dumb questions since I have never done this before. I bought a gasket and RTV silicone at Autozone. The instructions say it can be used as a gasket replacement, but I think the rubber gasket would work better (that's what is on there stock). Do I apply the RTV sealent to the valve cover side, head side, both, or not at all? Also, I read if you tighten it too much, you can distort the shape of the cover and cause leaks. Should I be anal about it and buy a torque wrench? Or just tighten it back on snug?
Thanks in advance
Thanks in advance
