T-5 behind a 1960 f-100 223 engine
FlimFlamMan
Hi guy's, Now that I have started asking questions it seems I have more I want to know.
I now have a T-5 Trans. that came out of an 84 T-Bird. It is a 13-52-018 23721. I' not sure of all the gears ratio. 2.37 fits into the ratio somewhere and I believe .86 is the overdrive. I have found that is not a world class model. Where can I look to find out the rest of the ratio? But I am thinking for the price it will work for a while, ($20.00) It is all in good shape I have opened it up to see. Question: Is John Mummert's conversion the best way to go or is there other places that make the same type conversion for the T-5 behind the 223. I have now a 1960 F-100 with 223 and a T-98 trans. I also am running a 3.73 rear axel. What do any of you think of this combo. Ya think it will work out OK? As always any infor good or bad is appreciated. :thanks:
Thank you JimKoz, I was wondering about that. I thought I had to have a three speed bell to send for core. Now I know. I will be talking to him on Monday. Thanks Again. :thanks:
for your ratio stuff
http://www.britishv8.org/Articles/Borg- ... D-Tags.htm
if you search for "T5 identification" on google, you might be able to find the max torque rating
Thanks Aza, I have been trying to remember that British site. I have seen it before. I am still wondering if I will like what I have when it's done. I will do some surching and see if I can figure what me rpms will be in fith gear. I think take off will be fine with the 4.03's
i seem to remember a fair amount of people recommending something around 3.5-3.75 or so for a rear-end, but that was for a Mustang or Falcon with a T5
don't forget to factor in tire size, especially if you're going to upgrade your rubber for something a different size
Thanks I will keep that in mind. Right now I found out that mummert only converts the 3 speed bell with the pick/up mounts. So I am looking for a 3 speed bell. For now everything is on hold until I can find one. Still have plenty of other things to do. I have the whole front end appart getting it cleaned up for paint. No problem. If anyone out there knows of a bell I looking for let me know. I am ready to do this.
Thank again Asa
hey flim man. if you convert to the t5 and are not too far from st louis let me know and ill buy your t98. e mail me fordtruck52@yahoo
