T3?
Would a turbo off a turbocoupe the t3 be enought for a few pounds of boost on a 300 six?
- Chad
A while back, I had a bad case of turbo-fever. IIRC, the T3 Super 60 trim was highly recommended... in my case, I was considering up to 7 lbs. of boost.
Read the compressor map!
At 7-8 PSI and a max of 3800 RPM, the T03 Super 60 is very nearly perfect. More boost and more RPM move you into a small-trimmed T04.
So if you're building a turbo 300 for towing/hauling or otherwisw acting like a truck, the T03 is the way to go. If you're looking to build a heavy, unaerodynamic, nose heavy hot rod than the T04 works better.
