Thinking Transplant
Thinking about transplant :idea:
Mill in my Ranchero needs going thru, 65 200 leaded motor need input
have Pertronix II ignitor Clifford six into two header with port devider to be installed. also changeing from manual three on the tree to C4 auto
also end up with two bbl H/W and a small cam to help it all work
head is hang up have hard seats installed and guides? aquire later model head? Other ?? Is it worth while to rebuild an 80 model Fairmont 200 as the base for these mods or is it as tough a platform as the 65 block? I have no ready info about the later model 200 Would appreciate
your input I am going to have to spend some$$$$ But would starting the build with a motor that is already an unleaded head and I assume the bigger log a better bang for the buck Thanks.. :roll:
Building the later block should not be a problem. There have been changes in the cylinder heads along the way. Different CC's bigger log and so on. Upgrading to a OZ head would give you more power. One thing you should do before anything though is get a copy of The Ford Falcon SIX Cylinder PERFORMANCE HANDBOOK you can find it at.
http://falconperformance.sundog.net
