nickstewartroc
I had problems after doing the 2v carb conversion with a finding a suitable throttle cable. However, I finally found a perfect one.
http://www.jegs.com/i/JEGS-Performance-Products/555/157006/10002/-1
I didn't think that a finding a throttle cable with a 36" sleeve would be so hard! The hardest part was finding someone how stated that the sleeve is indeed 36" instead of the generic 36" throttle cable, where the cable is 36" and the sleeve is 24". It is also one of the cheapest cables I found period. I got mine installed last night, and thanks to the nice instructions it was really simple and only needed to trim off about 6 inches.
For the carb side, I used a bracket like this: http://www.jegs.com/i/JEGS-Performance-Products/555/157050/10002/-1?parentProductId= However, I found an off brand one on ebay for much cheaper, and works just the same! I did have to bend it slightly so the throttle cable adjuster nut wouldn't hit the valve cover. Nothing a pair of pliers couldn't handle!
For the accelerator pedal, I'm still trying to find a better setup, but for now, and for about a year, I've been using an ebay knockoff one of these: http://www.jegs.com/i/Lokar/625/BFG-6012/10002/-1 but I had to make a spacer to lift it off the floor pan, so I used some square steel stock I had laying around. It works, but want something that not only looks better, but has a better mount.
EDIT: Looks like this should work for the throttle pedal: http://www.jegs.com/i/Lokar/625/BAG-6115/10002/-1
I'll take pictures and attach as soon as possible!
