tri-power 250
I noticed after running the engine, there is fuel leaking from the choke side of my Holley throttle plate. I pretty much know it from the throttle shaft area. Is there something I should have done after I removed the choke? Is there a spacer or something I should have added, or is my throttle plate just worn out? Is there a rebuild kit to fix this? Again I only noticed the leaking after the engine is shut off.
Thanks,
Ken
Thanks,
Ken
