I was putting the timing chain cover back on the 200 6 cylinder for my 1966 convertible mustang and one of the bolts just turned inside the hole instead of getting tight. I pulled it out and noticed it had stretched and cracked about 3/8" up from the bottom. I don't know how I got lucky enough that it didn't break off down inside the block!
Does anyone out there happen to have an extra timing chain cover bolt like the one I need? The threads are 1/4 - 20 and 1 3/8" long and the head takes a 3/8" socket to tighten/loosen it. I know that you can buy a replacement set from National Parts Depot, but I only need one bolt and I'd hate to have to buy the whole set.
There are two lengths of the bolts on the timing chain over -- this is one of the shorter ones. I'm including a link to the picture of the bolt that almost broke for reference.
Thanks in advance if you can help me out!
Chris
https://drive.google.com/a/laramie2.org ... sp=sharing
Chris
