There are lots of marks and nicks on the crank pulley closest to the timing plate, and I can't figure out which mark I'm supposed to be looking at for setting the timing. They all just look like nicks in the metal, none like it was put there on purpose. What does the proper mark look like?
Also, what are the numbers on the timing plate? It looks like 14, 10, 8, 6, TDC but I can't tell for sure. I assume the numbers are all before TDC, right?
I was fooling with the timing today and I can advance it so much it stalls, but I can't make it ping. I'm hoping the timing is set way off and that is why it gets such horrible mileage and makes so little power, but it ran very smoothly when I started. I checked the advance and it does seem to work - the marks on the pulley advance when I rev the engine.
Any thoughts on this? It's for a '67 Fairlane with a 200.
