Ok,
I finally got the engine back together tonight. I installed an FSPP Cam (CSC-264-12-DHS), Milled the head 60/1000 for a CR of 8.7:1, ported the exhaust, installed an new FSPP balancer, adjustable roller rocker assembly, etc.
I had some trouble getting it to idle so while keeping it running I adjusted the timing by ear and it idled fine. When I checked the timing it was about 45 degrees advanced with vac and about 30 degrees advanced without vac. Going down or up in timing made the engine run poorly. I assume I might be able to get the engine to idle with less advance if I reset the carb, but the engine ran fine with these carb settings previously and I don't want to add any more variables. I used a timing light with an advance degree dial to get the measurements, and also verified the balancer was showing TDC properly and marked when the rotor passed the number one plug wire post and all point to accurate results.
Additionally when degreeing the cam I got some numbers slightly different from the cam card. I had emailed Mike and he told me to contact Clay Smith, but Clay Smith never got back to me so I figured I'd see how the cam ran. I never did get back in touch with Mike, but below is the Cam info. My gut tells me the cam is not theproblem since the lobe center was not off much.
Thanks,
Greg
I've re-done the lobe center procedure multiple times now at 50/1000 and 35/1000 from the lobe center (measured off the lifter) and consistantly come up with a lobe center of 112.5 degrees and an off set of 4.75 degrees advanced.
Additional numbers:
Lift multipled by 1.6 ratio: Exh 0.472, Intake 0.464
Duration at 0.050" measured at lifter: Exh 228, Intake 211.5
Thanks,
Greg
Additional numbers:
