MustangSix":3pt26wnf said:The only bolt-like thing under the rotor is the point cam. I can assure you that if you put a socket on it and turn it hard enough, you will either shear the roll pin on the drive gear or strip the gear entirely. This will definitely affect oil pressure, but probably negatively.
Look at the oil pressure sender to the right of the fuel pump. If the wire comes loose and hit a ground, it will peg the gauge.
Well yeah, there is that - but that wasn't quite what I had in mind
