Here's a bit of history: I have a 68 200 in my 63 falcon 'vert that has an exhaust manifold leak. I tried to pull the manifold but ended up breaking a couple of bolts. I then pulled the engine to try to remove all of the rest of the bolts without breaking any more and to drill out those that did break. The top end was surprisingly clean when I removed the valve cover to attach the lifing chains to the head bolts. After pulling the engine, I noticed the rear freezeout plugs looked new. I also noticed the head gagket was fiber and beasured .050" where it was sticking out between the block and head. When I got the exhaust manifold off, I was surprised to see a port divider already installed.
Now for the questions: Seeing the gasket was already replaced, I pulled the head. The cylinder walls are clean without scratches but the cross hatching is gone. I'd guess the engine has probably 15 to 30k miles on it looking at the amount of "crud" on the valve train and wear in the cylinders - even that might be high. Back in the day when I worked at a garage, I recall seeing a lot of sludge on the sixes when replaing valve covers. I can slide a .015" shim between a straight edge and the edge of the piston top. So what to do? I don't have a bore gage to measure taper and I don't know (yet) what the CC's are for the head. My goal is to have a reliable weekend driver with a bit of punch. I have a HW 32/36 to put on it and will be upgrading the dist to a DUI. I figure I should at least get a 78 or later head although a CI or OZ would also be do-able. It's apart, so now would be the time to put in a cam. Would you guys at least re-ring it if the cylinders are straight or leave it alone? I don't want to spend if it doesn't have to be spent but want to do a reasonably good job. FWIW, I also have a 3.03 to put in it as soon as I find a yoke and driveshaft that can be modified to fit. Thoughts???
