Has anybody had experience with excessive pinging on a 200 ci 6? Does anybody know what typical numbers of total advance timing should be?
The engine is stock but I have replaced the distributor on my 67 Mustang with a Durasparc II. The centrifugal advance was on the "13" tab and after some experimentation I reduced the gap and ended up with about 6 deg total mechanical advance. I also had to limit the vacuum advance to about 6 deg as well. My static timing is set to 12 deg for a total amount of advance of 24 deg. The engine no longer pings but I can't help but think that this value is extremly low as some of the figures I read about are in the 40 deg range.
