hello folks..... thanks for all the help you experienced folks have lent me the past couple years with my 200ci. Over the last 2 1/2 years, I have had my engine rebuilt twice by a (seemingly) reputable local shop. However, I had to re-rebuild the engine when I burned pistons 3 and 4 after about one year on the road.....(they warrantied the top end, not the bottom- cost about $900 the second time around after $1700 the first) I have not as yet discovered the culprit....... but have considered possible dizzy and carb issues primarily (I recently installed a DS II, and I've been playing around with a weber 32/36 recently still working out jetting)...... SO HERE'S THE PROBLEM: After all this tinkering, I recently discoverd my exhaust manifold was glowing red hot when driving up the long steep hill to the mountain village where I live- I assume this can't be normal. I am worried I still have the same problem that caused my engine failure after such a short time- and I can't concieve of what it could be except an intake leak- I have a stock early 80's head, and have had low compression numbers, even since the rebuild from (cold) 90 psi on the low end to 120 psi on the high end. My cyliners are I believe thirty hundredths over, and I couldn't convince the rebuilder to mill the head to restore a higher compression......Any advice will be greatly appreciated...... sincerely.... david soCal
