Yes,that sounds like a good setting to try.
Pinging sounds like sharp "clicks" or "rattles" when the throttle is pressed down under load. It can be random or continuous and can vary in intensity,but it is hard on parts and should not be ignored.
When you hook up your timing light next time,unhook the vac advance and see what max advance you get by 3000 rpm. Try adjusting for 32-34 degrees at 3000 rpm without the vac hooked up,then hook up the vac and drive it to see how it works.
Terry
Terry
