Triple one barrel carb set up
Doing an upgrade and i want to put triple one barrels . I was looking for someinformation on how to set it up or pictures if anyone has this type of set up. Anything will help. I have a 1978 head with the flat log .If that makes a difference for the setup. Thanks
Nazs
You will probably want to get a offy tri carb set up. It is not to bad to install plus it will have all the linkage needed to make it work. Clifford has them along with vintage car parts
I am inspired. I especially liked your final linkage design, clean and simple.
Q: which carbs were you using?
Ric.
I'm using Autolite 1100s...I went with them because they are shorter then the holleys or webers.
Also...the one on ebay just looks like an older Offenhauser intake.
Slade
