Triple SU's Fittment
Not a piece of cake to tune. It can be done if you have a syncrotester or three vaccum gages, and you make sure the brass jets and needles are okay. There is no subsitute for rolling road work, as the set-up needs to be dailed in to a correct cruise and power CO level.
The stock HS6 carbs are 1.75", and flow about 205 cfm each. Peak power is 106 hp per carb, so in theory, 318 hp is possible, but not with a 200 in a mild state of tune.
There are a variety of main jet and needle types. There are bias swing needles, and 90, 100 and 125 thou jets.
The best option is to use the larger 100 thou jets, and use a needle similar to the OA6 needle used in later aftermarket triple carb kits. 250's seam to like the bigger 125 thou jet, and aftermarket needles such as those used in Aston Martins and Jags.
The carbs look like old Leyland Tasmin or Kimberly or P76 Morris Marina items which were seen with 1750, 2262 and 2600 cc OHC engines.
There are some issues with dashpot drop rate, and the spring rate of the piston spring, and additinally, the kind of oil to use.
These items work very well when tuned by a loving Ford fanatic such as you. After its dialed in, I'd suggest getting an oxygen sensor, and monitor the tune with a volt meter.
One thing with SU's is that they produce excellent low speed torque with good economy, but they hate heat soak and high fuel pressure. The leak because the parts don't have a high aromatics resistance (the English never used unleaded untill 1989, and those carbs are 1970's items), so ensure you use good fittings. Alex has made an excellent sheetmetal cover which ensures the heat from the extractors/header doesn't end up boiling fuel. I'd restrict the line pressure to 3 psi with a fuel regulator.
They polish up delighfully, and the K&N stubbstack and filters need to be used to avoid the air cleaner restricting the airflow and therefore jetting requirements.
It'll probably bolt on and sputter into life. Watch for redbacks in the carbies!
They're very simple carbs. You can rebuild them yourself provided you have access to a reamer and hone for the throttle shaft bores. These are most easily rebushed with spiral Teflon sleeves after a 20 thou ream/hone.
Avoid Burlen Co as far as possible in favour of SU Midel - simply for price reasons. Otherwise see if you can get kits off a place like Rimmer Bros. The pound is expensive on conversion! There is a website where you can decode the ID tags but I can't remember it right now.
My experience with SU carbs is limited to my mate's car. It's happiest not sitting more than a few days without a good "blat". Old style tuning was with colortune plugs and a vacuum synchroniser.
If you're game to pull them apart and rebuild, all the blah regarding dashpots and oil and jets will make more sense and seem rather simple!
Post and tell us how it goes! That was way cheap as a rare score and you have done very well.
Cheers, Adam.
Thanks for the remarks guys. I am very excited to get them. I watched the auction all week in anticipation and had to get up at 3:30am this morning to make the final bid. I'm sure I'll have questions once I start messing around with them about things such as dashpot drop rates and oil type? Heck I wouldn't know a redback if I met one. But the cool factor is way up there. Especially polished. Great idea. Ebay really has a lot of cool intakes come up from time to time if you watch for them. There's a four barrel cain on there right now for a cast iron crossflow. I've been looking high and low for an alloy head crossflow intake but haven't had any luck. I'm assuming somebody makes something for the alloy head.
Here's the link for the four barrel intake if you need one. I believe this is for a cast crossflow but the add doesn't say.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... %3AIT&rd=1
I really would like a Dellorto set up but don't have a clue on where to find one. Oh well, Have a good one...
Dave
I may be thinking of a Weber set up. They kind of look like Dellotas.
Hey, I don't mean to rain on anybody's parade, but does that intake really fit a 2V head? I looked at the bolt pattern on my Lynx 2V intake for the triple SU's, and just can't find the match. The port spacing looks right, sort of like a Nissan 280Z - close, but no cigar! It might take a home-made adapter plate to mount it. Hope it works out.
8)
I'm not sure that it fits. It didn't really say in the add, but that's why I asked. I thought it looked like a 2V inlet. I guess I'll know for sure once it arrives.
Ah! Good catch K6. That's a Lynx "DIY" manifold. I've got one identical. You braze a plate to the milled up log head, at a 30° angle to the vertical. Drill and tap the four mount holes and that's it.
What are you telling me Addo? Will this thing work for me if I build a plate or is this for something totally different? I'm thinking maybe cutting the plate off of another intake. So what's a "Do It Yourself" manifold designed for?
These were designed back in 1962/3. The 2V head wasn't even a twinkle in the engineer's eye back then. They came as the manifold, instructions and maybe a cast iron plate to weld/braze to your head.
You generally fit them to an earlier log head with more round runners. To make it work with the 2V you would need to mill the faces parallel and weld some more 5/8" thick alloy on for a new 2V pattern mounting flange. Could be touch and go for the port matching.
Sorry I can't be more help than that! Haven't machined my test-head yet to try the one I have hanging up. I don't really think it's hard; just a little outside the box - we get so conditioned by parts that require no brain stretching.
Adam.
No dought. We live in a world of plug and play. It's really kind of cool, while I may or may not use it on the 2V, I'll be bringing it over to a world in which it was designed for. A world of log head motors with no performance parts. I have other options for the 2V but if it's real close who knows, the cool factor is way up there and they can work well. The fact that it will work on a log head really gives me more options.
