'68 200 with stock internals, DS/HEI ignition, Autolite 1100 carb and a diy-ported exhaust manifold. 3-speed manual tranny, manual choke.
Just got my JAW wideband together and in the Ranchero, (see this thread), and here are my AF ratios at various points:
Idle: 13.7-14.3 (this is the only one I've adjusted yet)
WOT: 12.0-12.5
Part-throttle cruising under 50mph (just loafing along): 16-18
Cruising on the highway at 60+: 16-20, and the faster I go the leaner it gets and the wider the swings - which are pretty fast, it gets pretty hard to catch the numbers changing on the display.
From what I've read, the idle and wot are ok, but the cruise AFR's are pretty lean (even though it's been like this for about a year and the plugs look good.)
One thing that concerns me is the speed at which the AFR's spike/dip, at 70mph or better the digital display is jumping between 16.something and 20.something so fast it's hard to tell what's what. I'm working on borrowing a laptop so I can datalog then average, but surely it's not normal to change so much so fast, is it?
Comments anybody?
WOT: 12.0-12.5
Comments anybody?
