All Small Six Tuning help requested for 32/36 weber
chad
5K+
Supporter 2021
Supporter 2020
Supporter 2019
"...Get an air fuel ratio via a wide-band tester..."
there ya go...more parts, but toward perfection~
Dragonlich1961
Installed an afr gauge finally. No changes have been made since last time.- i'm at about 12.5 at idle- bit rich. cruising is about the same- i added a bit to the primary main jet- to help with the WOT throttle pinging- and it helped- but i think it helped by adding fuel across the whole board where as I only need it with the secondary's. WOT pull and i watched the gauge dive into the 14-15 range and some times it hit 18-( accompanied by surging and lack of power). this is also the hottest day i have driven the car- so not sure if that was also a fuel boiling issue. But none the less WOT is lean. yet seam like low end is rich. thinking pull the jet from the primary main jet and back it back down to the 150 originally and stab a bigger secondary main jet at it.
Also noticed a big change in idle afr when the AC was kicked on(.5-.75 swing). Need to figure that one out still
chad
5K+
Supporter 2021
Supporter 2020
Supporter 2019
a lill in the signature line would help us as we would not have to go back & read it all to find the important stuff on this rig for problem solving/recomendations/advisement (drive train, carb [o0OP I C now], ignition, gearing, type of transmis, etc)
Dragonlich1961
Just updated it. Sorry about that.
wakjob
Supporter 2020
How'd ya make out with this?
I had to use 85 Primary / 65 Secondary Idle.
Mains 160/150 just to get SOME color on the plugs...mine engine was hot & LEAN before with the stock jets.
Dragonlich1961
I'm still playing with this thing. It's fun to drive and I've been busy much of late. Got married, which was the event that I could not miss, nor could Sunshine as she was the chariot. Also bought a house. Shortly after that drove it to work one day and the cam gear decided to hop off the cam. My fault- looks like the cam spacer was installed backwards( chamfer away from cam) by my 19 year old self 6 years ago and broke, which caused the cam gear bolt to loosen. Opps. While putting it back together, found the carb was slightly loose on intake- good 1/2 - 3/4 turn. After that I'm back to the pinging, but my O2 appears to have died. I suspect I'm back to lean. I'm running a 160-180 main jets. And before the carb tightening my WOT AFR was still in the 13's, I'm amazed as to why i'm having to get it this much to close to my afr. I'm back to getting similar symptoms was I was before I made a big change to the mains before.
wakjob
Supporter 2020
Well congrats on the wedding my friend!
My cam bolt was loose by nearly 3 turns out with a broken thrust plate due to not even having the thrust washer installed. There will be over 3mm of end play without that spacer (also known as the "wedding ring" :LOL:). The cam whacks back and forth with acceleration & deceleration to the back freeze plug to the front thrust plate/washer. Something will give up and break at some point... usually the thrust plate, and hope the timing chain cove holds everything back, stopping the cam gear from shearing off the dowel pin ect...
It's good practice to put BLUE Loctite on that bolt and torque it to the high side of the spec spread.
Now that I have a full exhaust system on the car, I had to go down on the Main Jets to 140/150 with 160/170 Air Correctors.
Idle jets have remained the same 85P/65S.
Could not get the 38/38 to run, so I put the 32/36 back on.
I'm running out of nice weather up here, and just want to drive and enjoy the car before I have to store it away for winter.
I'll monkey around with the 38/38 in the spring.
Just_Fare
Active member
Dragonlich,
Are you running ported or manifold vacuum advance to your distributor? I was having similar issues with mine and switched from ported to manifold and solved my pinging issues at heavy throttle. As I understand it, using ported vacuum will, at higer throttle, advance the distributor from both the vacuum and the machanical advance within the distributor thus giving you too much advance. Manifold vaccum will drop the timing as the mechanical timing kicks in, which is what I think you want. You will have to watch for pinging when cruising at high speeds when you back off of the throttle.
Additionally you can get a synchronous kit to change your 32/36 from a progressive carb to a synchronous ( similar to the 38/38 ). This is what I'm currently using and the gas pedal doesn't have to live above 50%. As others have stated, the 32/36 is an economy carb out of the box, but if that's not exactly what you want, the synchro kit is a cheap way to get some pep out of it. It only affects how the pedal - carb feels, it does not improve overall performance and basically kills any fuel economy benefits that the carb would have had.
Beauty of a car/truck by the way,
Chris
chad
5K+
Supporter 2021
Supporter 2020
Supporter 2019
"...get a synchronous kit..."
I wouldnt. But I'm only 1 guy.
"...it does not improve overall performance..."
(performance = pep AND MPGs) at any rate a few have come in here w/the linkage locked out (turned a beautiful progressive into a 'regular') and its a bear to jet right, improve performance. I gave up eventho the customer was happy (still smelled, could not be seen anymore). Just usea holley or other made 4 it...
Dragonlich1961
Dragonlich,
Chris
i'll have to try manifold vs ported. It's using ported right now, but I'm having timing issues at higher rpm and under load. I'd love to get a holley system for the car, 2300 sniper with dizzy and hyperspark. Wasn't out when I built my set up. I really want to get a vintage inlines head and drill the intake for multiport fuel injection, running a holley dizzy and computer. I can't really drive at full trottle much due to the pinging. On a plus it's getting 22 mpg on the highway at 85.
chad
5K+
Supporter 2021
Supporter 2020
Supporter 2019
"...drill the intake for multiport fuel injection..."
those bosses just sit there waitin for the injectors (don't they...
