You got me wrong, most of the wild cams I put in can't get down to 1000 rpm.
Never punctured a piston.
To get best performance max cyilnder pressure should occur ~13°. Lean mixtures burn slower, there is no way around that.
What I think you are referring to insofar as advancing with lean mixtures, is actually the gross dilution of A/F at idle with big cams... the mixture going in is say 11.5:1, but the effective fill mixture is lean?
The fact that a dizzy loses vacuum advance under load (as VE rises) is a clear indication of the requirement to retard as A/F increases.
Just programming an ECU readily shows the relationship between lean burn and ignition advance.
