i have a t-5. seems there is an issue with a manual transmission and a turbo?
StrangeRanger":2gun9hkx said:The only "issue" is that you cannot load the turbo prior to launch with a clutch the way you can with a torque converter and trans brake.
Linc's 200":24rd0yju said:The way to solve that problem is with a MSD "two-step", which allows two different rev limiter settings.
Of course, there's a whole lot of popping and banging out the exhaust, because the MSD limits RPM by cutting spark, but once the light goes green you'll be running on all six again and off to killer run (if you have traction)
hasa68mustang":2h9wmajg said:1) I thought I had read somewhere that it was actually bad to have a car backfire because it can damage the blades of the turbo... but I knew thats how you build boost
2) but with a larger turbo could you do the same with the auto?
80broncoman":2h9wmajg said:1) The MSD unit will kill cylinders in a ramdom manner. that is why all the poping and banging Do the ones they sell now still do this?
2) There are rev limiters that do not do this. Crane Ignition units don't do this.
3) However thier catalog units that they came up with around 1991 will not work on a 6 cyl.
asimmons04":22c65ry9 said:what if i only reved the car (using a tach) to about 3500-4500rpm before launch and no higher?
that would work just long as i dont rev that high?
asimmons04":12ku3yog said:what if i only reved the car (using a tach) to about 3500-4500rpm before launch and no higher?
kirkallen143":pu5t44ct said:1) What if you used the white wire off the DSII to retard timing to help build boost at the start line?
2) And when you are shifting while running down the line, I don't think it would make that much of a difference when engaging the clutch because you would be in and out of it very quickly.
asimmons04":1eog8his said:i guess that would make sense. now to find a turbo? lol
fast64ranchero":37ayp6hj said:this is done by clipping wires on the outside of the box,
Linc's 200":3kk0n7tq said:fast64ranchero":3kk0n7tq said:this is done by clipping wires on the outside of the box,
Mine has no external wire to clip
