TURBO tech
Well i just got a turbo for my I6 and i dont know if it will work on my engine. I got the turbo from a Dodge Cummings and i was wondering how i would hook it up to my 200 six. If anyone can help me please do. Thanks.
An HX35 is probably too big for a 200, but it is perfect for a 300. I guess you'll just have to swap engines :wink: Imagine how fast your Falcon would be with a 300 turbo.
It would be god awful fast. Can you build up the six to handle that kind of torbo cause I think my six can handle it. One other question is that how would I hook the turbo up to my header or exhaust manifold?
If you dont have any previous knowledge of turbos. I strongly suggest doing some homework first. There are lots of books with great information. Maximum Boost is a good book to start with.
This turbo is too BIG. Way too big. Get a turbo from a engine of the 2.2-2.8 litre displcement. Your 200 doesn't have the exhaust flow to spool up a turbo that size. You would have to rev the motor to 3800-4000rpm to get any appreciable boost. You are looking for a turbo that will bring the boost all in by 3500-3800rpm as this will work within the regular operating range of the engine. Also remember to upgrade your cooling and ignition to deal with the new boosted setup. Good luck!!
well people are running hx35's on 2,3L fords with no problems... the prob would be that you need a motor that can rev high (4-5K) and take 18psi of boost to make use of that hx35.....if you wanna sell it....
nick
