twin turbos
I spec'd it out once and two eclipse turbos would be damn good for mid-range power on a 300. so would be top-end builders on a 200, and the lag would be there.
Now is this running them in series or parallel? Theres a couple different ways to run both the intake and exhaust of twin turbos in series and parallel configuration, in which case you would have to recalculate. I'm assuming parallel as it is two of the same small turbos. I always wanted to compare differences in how twin turbos were configured to see what the effects of each configuration is. An inline engine makes it much easier to pick all the options too.
Running them in series is useless for a 200, since we don't have headgaskets that can stand 30+ psi. Or pistons.
