Using the right coil
Will a coil for a '66 points ignition work with a DS II conversion? If so, can I still use a larger spark plug gap (i.e. 40-44) or will I have to use a smaller gap?
-Chris
You can use it.
I don't think you'll be able to open up the gap much since DS2 doesn't really give you more spark energy.
Slade
You can also swap to a MSD blaster 2 coil for around $33.00 from Summit :D :D
Later,
Doug
