Got my new (salvage) motor in and it fired up on the first turn of the key! Unfortunately, it only ran about 15 secs. and quit. Turned out to be the cam gear on the distributor. spun the roll pin. fixing that tomorrow.
Need help on the vacuum lines and 1 electrical connector . The connector comes from the ECM from the the same group that feeds the coil. I think it's for the choke? Any other place it might go? [http://i103.photobucket.com/albums/m150/sargentrs/000_1003.jpg]
There are 3 vacuum connectors on the carb that I can't remember how they go. Top one is comes right out of the throttle bowl. #1 is in the center of the carb body (behind that vacuum diaphragm). #2 is at the bottom of the carb and angles off toward the front of the engine. I've got two places to get vacuum, a tree on the manifold (#5), the hard line goes to the brake booster and 3 ports on the the vacuum switch on the thermostat housing. What should feed to where? There's 2 more lines that need/supply vacuum, I think. One from the firewall (#4), pass. side, and one from under the the exhaust mani (#3). The one from the firewall starts out as a hard plastic line and ends in about 6 inches of rubber line. The one under the mani. is steel and ends in 6 inches of rubber.
http://i103.photobucket.com/albums/m150 ... 0_0998.jpg
Can somebody how to hook all this up for the best carb perf? http://i103.photobucket.com/albums/m150 ... 0_0997.jpg
[/img]
[/img]
