I just rebuilt my solid lifter 170. I set the valve lash .016 cold. Now I find out it should be set hot. I don't like the pounding the valve train takes with big valve lash. I also don't like valves not closing good because of small valve lash. The way they are set now sounds like plenty of clearance. I know you can't set by sound, BUT, still sounds like plenty of lash. My vacuum guage sets just as steady as can be with 23" @ about 700 RPM. No indication there of to tight valves.
Should I reset the lash with engine hot. I wonder what the lash will be now if I check it hot? .001, .002, .003 less or how much? I'll find out because I'm going to check even if I don't change it.
BTW, less than 50 miles since rebuild.
L.D.
L.D.
