At the moment I'm looking at the original 170 1.5 ratio rockers. There is evidence on the surface that pushes on the valves that the valves spin. It also seems that there is an angle cut to the rocker to valve contact surface, my guess is that it is put there just for the reason of spinning the valve. The combination of the angled rocker surface and valve sweep would impart a torque to just one side of the valve stem, and thus rotate it. I have heard in passing before that the valves rotate to reduce wear, and it makes sense that a non-roller rocker arm can cause the valve to spin, but if you were to switch to roller-rockers are they also designed to spin the valves?
It seems to me that in placing roller-tips on rockers it would significantly reduce the friction found in sweeping the rocker arm across the top of the valve stem. (Hence the purpose of roller-tipped rockers) However, in reducing this friction, how is the valve then rotated?
I haven't been able to find anything on the internet about the fact that the valves are rotated. Is this a closely guarded secret?
