Hey all. You may have read my post a bit ago about a problem I was having with the #2 cylinder...ended up being SOMETHING along the lines of a stuck valve or mal-adjusted rocker arm assembly. I had VERY low (nearly 0) compression on #2. I pulled that rocker off, reset the adjustments from scratch and viola. Back to running great. It almost seemed like one of the pushrods was up to high or stuck up to high. What can cause this and how do I correct it?
Unfortunately, that wasn't the end of it. Not long after getting her back into shape, the same symptoms have now crept up again. Running like crap. SO, i went about the same solution. This time, I pulled every rocker assembly off, reset the adjustments, bolted it back together, and once again, viola. She was running right again...for a while.
Driving her last night, she started acting up again after driving it a bit..but slightly different symptoms. Now, the engine has a bad surge to it at idle...like the same effect you get when turning a rheostat on a light switch..up and down and up and down. Down to the point that it would stall if I didn't throttle it up a bit.
I got home last night and fiddled with the mixture a bit and I seem to have corrected it...for now.
So, with my novela above completed, here are my ?'s:
1. I've STILL got the headers tied into my crappy old exhaust system for lack of $ to complete it. Could that constriction be causing backup and buildup in the valves to cause them to stick? Beside changing the exhaust out (which is happnening in the next few days hopefully), what can I do to clean up the mess in there? I've heard drizzle a tiny bit of tranny fluid through the carb...thoughts?
2. what would cause the valves to lose adjustment seemingly so quickly?
3. the surging I'm (was) getting...does it sound like fuel delivery issues? Could it be something up with the fuel pump surging fuel? I plan to rejet the Holley very soon as I know I'm way to rich. Could it be the idler circuit clogged up or something? Maybe powervalve blown?
I know it's super hard to do these online diagnosises (?), but I appreciate the effort! Thanks all!
