mach1 mark
Very high oil pressure; This engine is a relatively new build. About 6,000 miles on it. I have changed the oil 3 or 4 times already though its 6000 miles and never had a problem. I noticed just after the rebuild that the oil pressure was a little higher then the oil pressure on the old engine. Seemed reasonable to me: new engine, higher oil pressure.
But, recently I've noticed the oil pressure getting very high. Pegging the H on my idiot gauge in the car. The pressure drops down to about the middle of the gauge when I stop and ideal for a few minutes, then way back up to almost High when I punch the pedal.
The question is "what's the problem"; is there a bolt loose on the oil pump? Is the oil pump clogged? Is the relief valve in the pump stuck? Please chime in with any opinion. It would be appreciated. Thank you in advance.
