78 granada
Have any of you experienced a small amount of moisture visible between the head and block where they come together on the driver's side of the block?  I noticed this the first time I assembled my motor.  Not a lot and not running down the block - just visible.  I had to pull the head because I managed to pull one of the lifters out and flopped it on its side!  So I figured good enough I would just replace the Felpro gasket with another new one anyway.  So I reassembled everything with a new gasket.  Torque is right on.  Head and block are flat.  Had the head milled but used washers to compensate so the bolts wouldn't bottom out.  But still, I see just a bit of residual moisture when I run it.  Plugs look good - not like any amount of coolant is getting into the combustion chamber.  Really scratching my head!!  Is it possible this is nothing more than condensation?  Been offline for a while but good to get back on with you guys.....
Bill
			Bill
