Hey guys ,ive got a problem (not one i can fix with antibiotics).My 67 falcon runs an alloy head 250 xf engine with a xe falcon electronic reluctor type ignition.recently i have been fowling plugs on a regular basis.i been playing around with jets to rectify this problem after many hours of pissing around i did a spark test and noticed the spark seems pretty weak.
ive just removed the pink resistor wire (should have done this a long time ago)fitted a new coil and a new module and checked the air gap on the reluctor .still the same weak spark.ive run out of ideas ,patience and money anybody got ideas. luckly im getting sets of plugs for $12.50.
on the plug side of things on the xf they run the long reach projected tip
and on the xe the run normal plugs which plugs do you think i should run
the heads off a efi engine.
cheers dave 67xr6
cheers dave 67xr6
