Weber/Holley Weber ???
jimlj66
Is the Weber DGV, Weber 32/36 and the Holley Weber the basic same carburetor? Are they tuned and installed the same on our 6's? I found a reman Holley Weber for $75 I am tempted to try. It is listed as for a '75 Vega. Can I change jets/tune it for a 200?
The plan is for a mild cam, milled '82 head set up for pump gas. Will go in a '66 Mustang with a C4 transmission, stock gearing
As far as I can tell the H/W 5200 is a DFV not the DGV . They rotate different. I am by no means an expert those guys will chime in they know way more than I do. You can change the jets as you see fit. Have fun.
