Weber Question
strat1960s
I have a 65 Mustang with the 200/6. I picked up an awsome Aussie Head and a Weber 38 DGAS carb. Since I went with the Aussie Head, i could not use the stock linkage. I am going to go with cables on for the trans kick-down and the throttle. The Weber throttle control lever is set up for the stock linage. Does anyone know where I can find a throttle control lever that will accept both the throttle cable and trans kick-down cable. I have tried Weber and they couldn't help.
Thanks.
Ted
Go to your nearest wrecking yard and check out the 1978-1980 Fairmonts: I understand that the bracket that holds the throttle/downshift mounts will match up to the Weber. Take a good look, at least.
