Mercury Mike
I was reading my Mustang's book, and it says that when assembling a 170, to make sure that you use sealant on the headgasket. What's the best sealant? When bolting on the head, should I use any sealant in any of the bolts? I will put antiseize on the exhaust for sure.
I have a 200 that's already built, and only has about 5000 miles on it. It's ready to go. I can easily, very easily, reseal it and drop it into my ranchero. However, it ran like crap while it was in the car. 3/6 of the plugs were fouled to hell, and the pistons are all full of carbon. It's headgasket was leaking before I pulled it. My grandpa swore that he put a bolt through the #1 cylinder, but there was no hole there. The cylinder is a bit out of round. The piston is polished on the back, and carboned up on the front, right above the top ring. If I hone it and re-ring it, do you think it'd be okay? The cam has almost no wear on it, all the bearings look great, except for the #1 main bearing, which has a bit of an odd wear pattern. I will get pictures for you guys tomorrow. Just a bit of background on the engine.
Questions for the 200:
Hone and re-ring, re-bearing the main. Don't particularly wanna pull the crank. Would it be fine?
The threads for the balancer bolt are stripped. Somebody (not gonna say who) hit the balancer puller with a 1/2" impact gun, and beat the hell out of the threads. Can I chase those threads? Will that be okay on that part of the engine?
There was no oil-slinger. Isn't there supposed to be one behind the balancer on the 200?
Are the threads on 170 head bolts the same as for a 200?
What's the best way to clean carbon off the top of pistons?
Does anyone in SoCal have a hydraulic rocker set for a 200 that they're not currently using? =D I don't want to use my adjustable set. I will if I have to though.
Are 170 and 200 harmonic balancers the same?
What's the best way to break in a new head? I will be using a rebuilt head on an already broken in block.
Other than distributor, will everything from a '63 170 bolt onto a '65 170 block? Oil pump and all?
Also, if an engine has oil in it, and you pull the flywheel bolts out, oil is supposed to come out of those holes, right? If it's not, then that would be bad, 'cause that happened on dissassembly of the 200.
Thanks for any info guys.
