what cam with a 350holley and 2v head?
64xm
hey guys
i was wondering what spec cam would go well with a 350holley and a stock 2v head? also what jet should it have?
any help appreciated
thanks
brendan
Brendan, I highly recommend the 264 with a 112 lobe center for an automatic, or a 110 lobe center for a stick shift.
Really need to know your engine specs??
Also advance the camshaft 2 to 4 degrees.
The cam can by purchased from Mike @ www.fordsixparts.com
The camshaft is the 264 grind & has 214 degrees of duration @ .050
The 350 holley runs real nice on my engine using a 59 jet, use the stock power valve 8.5 & the stock accerator pump nozzles @ .031
Hope this helps, William
I agree with Williams's suggestions, the 214* @ .050" cam is a fantastic "all around" grind.
