I'm running 10" @ 900 RPM's or so....
Thanks,
Doug
Thanks,
Doug
Howdy Doug:
Relax Doug. 10" of vacuum with that cam is not too bad. At 110 degrees of lobe spread, you're getting quite a bit of overlap between intake opening and exhaust valves closing.
If you still have an auto trans (C4) with a vacuum modulator to help with shifting you might be experiencing some problems due to low vacuum.
The other factor is the big two barrel. Another factor might be high elevation.
If I were you I'd be trying a #5 Holley power valve.
Have you taken a drive with a vacuum guage hooked up and in the car so you can watch it? It would help you select an appropriate power valve.
MustangSix":3n5a2ex3 said:Doug, what is your cranking compression?
If the cam were too far advanced, your power curve would be higher in the rev range, but at the expense of low end power.
Since you have adjustable rockers, try this as a test. set the valve lash at something like .018-.020" and observe the manifold vacuum. Maybe even take it for a test drive.
You won't be able to keep the lash there, but a short drive won't hurt. If the vacuum is way up and the low end power is back, you may need to advance the cam a couple of degrees.
Mustang_Geezer":kqp7399x said:MustangSix":kqp7399x said:Doug, what is your cranking compression?
Jack,
Not sure what the cranking compression is? I dont have access to a compression gauge anymore so I cant check it right now until I get one![]()
I'll try readjusting the rockers for a test tomorrow and see what happens!
