What did I do?
ArtemisI6
Okay, the distributor has been so difficult to turn that I couldn't accurately time the car. I removed it last night and put a new o-ring on it today, and cleaned it up. Now it goes in and out and moves just fine. This is my first time R&Ring a distributor so I'm second-guessing myself at every turn after tonight.
At first the distributor would not go all the way in, so I had my girlfriend bump the starter with the key a few times so it'd line up with the oil pump shaft. I finally got it to go all the way in except for the final 1/4". I figured that'd be ok for now, let's see if the thing'll start. I get in to start the car and it cranked for a little while, maybe five seconds. Then as it was cranking it began to hesitate. It would crank, stop for half a second, then continue, then stop cranking again, then continue... then it stopped and would no longer crank. It didn't slow down, it just halted. I can turn the engine over with a ratchet on the crank pulley so I know nothing is getting in the way of the rotating assembly.
So I figured I'd check everything out with my voltmeter. I'm sure this is something simple but electrical makes my head spin and I got out of it just as I started to comprehend it a year or so ago. I have 12.6v at the battery, which is cool by me.
However, this is where I'm baffled. I have 12.6v when I connect one probe to the battery and one to the starter post of the solenoid. That's basically a big switch - it seems to me that it should be an open circuit, no? I also have 12.6v at the starter with the key off. I disconnected the starter cable from the solenoid and put a probe on the starter's battery post and on the positive battery terminal... and still got 12.6v. Just to experiment I touched the cable coming off the positive side of the battery with the cable going to the starter - basically bypassing the solenoid. There was a very minor spark but nothing worth mentioning. I've done this before on other vehicles, and on this one once or twice, and usually there's a hefty freaking spark and it starts to try to weld the cables together while the engine turns over. The only thing that happened this time was I heard a very slight hissing coming from the battery.
When my girlfriend turns the key to start I hear a click that sounds like it's coming from the voltage regulator, but that's the only response I get from the car. Also, I unplugged the voltage regulator and checked the voltages again and there were no changes.
I am completely and utterly stumped here. What did I do to this car? Please help me.
It's a 1967 Mustang with a 200ci and a 3spd with a Pertronix module, by the way.
