what fuel psi reg.
will type as little as possible (broken fingers) sry for short hand
i have a weber carb. i need a fuel psi reg. to keep it between 3-5. what kind are you guys running. local parts store is terrible. thanks :) when i can type more i'll be much more talk-a-tive
Your stock fuel pump should be just fine! No need to spend money on something that's not broke! :wink: look at my sig picture and you can see the top of my stock six fuel pump, and I'm running 8 lbs boost with a modified stock fuel pump!
I did the Does10's mod which is drilling a hole below the diafram on the fuel pump and attaching a hose to it and then boost referancing the hose to the supercharger. As the boost builds it makes the fuel pump think it needs to pump more and it does! Works really well, and is very easy to do!
I picked up a small gage and mounted inline just before the carb. I have a pre-pump see thru filter too. I am running 4.5lbs pressure steady with the 1100 carb and autozone reman-stock fuel pump.
