The later Mercury Zephyr/Fairmont/t bird/Capri/Cougar/LTD Fox 200 with 2.73 gears and 3 speed auto less than 92 hp is one of the worlds most unstressed engines. Same with the Falcon, Comete, Econoline, Mustang, Fairlane, Ranchero, Maverick, Torino, Early Bronco, Granada, Monarch, Varsailies
17 US cars that had it from late 1962 to 1983, I'm sure I missed a few
. Some years only got 250's, but there were around 40 million made based on an estimate made a few years back. On some of the Fox and X body lines, about 60% were I6's and not V8's. On the Fox Tbird, about 2% from 1980 to 1982, but on the Fairmont, most of them missed the good old 4.2 and 5.0, and got the 3.3 instead of the 2.3. Not that many Fox Mustangs got I6's, but its as common as the 2.3 or 4.2
Down here, our much more highly tuned 2-bbl 121 hp 3.3 Falcons regularly did well over over 290 000 miles before lifting a head.
The Fox bodies probably more due to having 30 % less power, higher gearing, less weight, more areodynamic bodies and better radiators than our old Aussie sedans. Being iron headed engine with a brass radiator core, it never needed too much in the way of engine coolant maintenace. Depends on oil changes. From what i can tell, a lot of US i6 Fox cars would be thrashed, and often sit on 70 to 85 mph range after the 55 mph limit got lifted, so actual use has more bearing on max miles than inherent reliabilty.
After the EFI 5.0 V8, which was noted in 1992 as having had the least warranty claimes of any Fox engine, the 2.3 carb Turbo the most, but the 3.3 was a
very realiable engine too. The 3.8 not so reliable due to head gaskets, but still a great engine. In fact, all vee engines (except the CA spec Variable venturi 2.8's and 4.2/5.0's) were good for high miles, just as good as the I6, but harder to keep well serviced due to intake manifold and dual exhast manifolds, ignition crossfire issues, whereas the six could limp on for 30 years with a leaking 1946 carb and malfuntioning emissions.
Another thing. These devices are often cheep second cars, so many a low kilometer rides exist. But even with 85 000 miles, guys are always saying "It's gutless but reliable and runs great"
