LameHoof65
Just want to run this by some of you out there. I have simply given up on the machining of my 77 head. This last machinist has had it since early Oct. and says he can't get to it. It's a long story, but the guy just was not able to get it done, don't blame him and I am not criticizing him, he had a good reason. At any rate I am thinking after 4 machinists, two of which specialized on heads and this one a performance machinist---well, I am just forgetting the machining part of this deal. It is a pretty true head and looks good as far as being square and flat. I won't have the desired compression or the 3 angle valve job nor the teflon seals, but I can lap the valves and I think the springs will work with the umbrella seals, so I can put the thing together and put it to my engine.
