G
The stock 2bbl intake takes a Weber pattern. I'm sure there are other 2bbl intakes out there. You can also go for the MPI, 4bbl, triple DCOE's, etc.. There are quite a few different options. Also, you have to consider that not all of the Crossflow heads are the same, they changed themselves over the years as far as chamber shape and notches on the intake side for fuel injectors.
For the dizzy, the DI setup may be just what the doctor ordered, otherwise your existing dizzy w/ a Pertronix will work just as well.
You'll not only need the cam from Oz, but also gasket sets and such. If you aren't careful, all the money spent to import over parts and modify blocks to suit may be better spent on a 302.
Another thing is that these heads have been out of production for over 10 years as well so we're still playing with obsolete technology :roll:
Al
Al
