Well, I called up the mustang shop about a distributor, They found a DSII for my engine, we can use my existing pertronix. They quoted me 120 for the setup, I really want to take it. (Best bang for its buck so far) I know that the economy will be less but I’d rather have a more reliable system. Adding a MSD box would be awesome…
The LoM I have is a 63 model, with a 65 LoM vacuum canister, It’s the only one i could find.
I want to know what you guy's think on the two kits I posted earlier for the steering and suspension. Anything for the steering and suspension that I should get that is not on those kits?
David- I have not looked into the steering box, or the vacuum. I’ll look at it tonight. Hopefully it’ll fix some play.
I did replace the head gasket earlier this year, I noticed the valve seals were missing or broken or not staying down, I didn’t know it mattered
 Now it's biting me in the butt... :arg: . I think I did the compression test wrong, it was warm but not up to temp…
When I started the engine after the oil compression tests were done I expected smoke, just not coming from the exhaust manifold
 every cyl is leaking. I think my manifold is shot. Will be the 5th time this year now… even used ultra copper. That’s why it’s so LOUD…
Btw- this is my DD and I’ve been driving it everywhere even with these conditions, it hasn’t failed on me yet, and I hope it won’t. the upgrades to the suspension will be slow as I would like to do it right, does anyone know of a good write-up of what to do for the suspension, I’m sure I’m going to need a spring compressor.
Richard
Richard
